KNXLive!
邢远 发表于 2013-7-6 23:47:13 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
KNXLive! is a Knoppix based Demo CD, which contains various programs for accessing a KNX (EIB) bus. This is not the project page for end users.
  • KNXLive! 0.2 and 0.3 is based on Knoppix 5.0.1.
  • The following packages are removed: openoffice-de-en kde-i18n-es kde-i18n-ru kde-i18n-nl kde-i18n-pl winetools wine fortunes-debian-hints kteatime gnuchess cowsay frozen-bubble xbattle ksudoku ksokoban xskat ace-of-penguins katomic kbattleship kreversi gtans xgalaga ktuberling xboing kmahjongg xboard libkdegames1 fb-music-low frozen-bubble-data scribus gimp-print gimp gimp-data digikam xawtv v4l-conf sCANtv dvgrab pia xawtv-plugins gtkam kooka xsane kfax gqcam startnessus-knoppix nessusd nessus-plugins nessus libnasl2 libnessus2 mysql-server mysql-server-5.0 squid squidclient squid-common tiger audacity isdnvboxclient sox vorbis-tools mikmod mpg321 speex sweep vcdimager gscanbus libkscan1 sane-utils sane xsane-common libsane-extras libsane efax efax-gtk kandy gpsdrive gpstrans radio aumix aletv configure-xawtv openoffice.org-debian-menus
  • The following packages are added:
    • bison flex libtool gettext texinfo zlib1g-dev libncurses5-dev libreadline5-dev dbs bzip2 libxml2-dev xchm
    • complette BCU SDK
    • tweety, basys, calimero, bcu1driver-utils
    • knoppix-graphics is replaces with knxlive-graphics
    • knxconfig (setup assistant, KNX Live configuration)
  • The following files are added to /usr/src:
    • /usr/src/linux-2.6.17/scripts/Kbuild.include
    • /usr/src/linux-2.6.17/scripts/gcc-version.sh
    • /usr/src/linux-2.6.17/scripts/Makefile.build
    • /usr/src/linux-2.6.17/scripts/Makefile.lib
    • /usr/src/linux-2.6.17/scripts/basic/Makefile
    • /usr/src/linux-2.6.17/scripts/basic/fixdep.c
    • /usr/src/linux-2.6.17/scripts/Makefile.modpost
    • /usr/src/linux-2.6.17/scripts/mod/Makefile
    • /usr/src/linux-2.6.17/scripts/mod/elfconfig.h
    • /usr/src/linux-2.6.17/scripts/mod/empty.c
    • /usr/src/linux-2.6.17/scripts/mod/empty.o
    • /usr/src/linux-2.6.17/scripts/mod/file2alias.c
    • /usr/src/linux-2.6.17/scripts/mod/file2alias.o
    • /usr/src/linux-2.6.17/scripts/mod/mk_elfconfig
    • /usr/src/linux-2.6.17/scripts/mod/mk_elfconfig.c
    • /usr/src/linux-2.6.17/scripts/mod/modpost
    • /usr/src/linux-2.6.17/scripts/mod/modpost.c
    • /usr/src/linux-2.6.17/scripts/mod/modpost.h
    • /usr/src/linux-2.6.17/scripts/mod/modpost.o
    • /usr/src/linux-2.6.17/scripts/mod/sumversion.c
    • /usr/src/linux-2.6.17/scripts/mod/sumversion.o
    • /usr/src/linux-2.6.17/arch/i386
    • /usr/src/linux-2.6.17/arch/i386/Makefile
    • /usr/src/linux-2.6.17/arch/i386/Makefile.cpu
  • The two BCU 1 drivers are build using the kernel source on the CD. bcu1driver is installed as eib-m.ko and eib.ko, eib-pei16 as eib-u.ko.
KNX Live packagesDO NOT INSTALL knxconfig OR knxlive-graphics ON A NORMAL SYSTEM (unless you really understand, what the packages change)
Filename
Last modified
Size
tweety_1.1.1.dsc
08.11.2006 18:40
259
tweety_1.1.1.tar.gz
08.11.2006 18:40
23.29k
tweety_1.1.1_i386.deb
08.11.2006 18:41
9.54k
knxconfig_0.2.dsc
08.11.2006 21:03
263
knxconfig_0.2.tar.gz
08.11.2006 21:03
9.57k
knxconfig_0.2_all.deb
08.11.2006 21:03
10.46k
calimero_1.4.dsc
08.11.2006 09:53
269
calimero_1.4.tar.gz
08.11.2006 09:53
401.4k
calimero_1.4_all.deb
08.11.2006 09:53
401.17k
basys_2006-0.1.dsc
08.11.2006 19:10
272
basys_2006-0.1.tar.gz
08.11.2006 19:10
13.63M
basys_2006-0.1_all.deb
08.11.2006 19:10
12.6M
bcu1driver-utils_0.5.dsc
08.11.2006 09:51
285
bcu1driver-utils_0.5.tar.gz
08.11.2006 09:51
45.81k
bcu1driver-utils_0.5_i386.deb
08.11.2006 09:51
9.61k
knxlive-graphics_0.2.dsc
08.11.2006 13:41
280
knxlive-graphics_0.2.tar.gz
08.11.2006 13:41
1.81M
knxlive-graphics_0.2_all.deb
08.11.2006 13:41
388.58k
tweety_1.1.dsc
08.11.2006 09:51
255
tweety_1.1.tar.gz
08.11.2006 09:51
23.29k
tweety_1.1_i386.deb
08.11.2006 09:51
9.47k
eibddemo_0.1_all.deb
12.11.2007 22:42
147.43k
eibddemo_0.1.tar.gz
12.11.2007 22:42
34.82k
eibddemo_0.1.dsc
12.11.2007 22:42
282
calimero-ng_0.0_all.deb
14.11.2007 07:15
608.91k
calimero-ng_0.0.dsc
14.11.2007 07:15
305
calimero-ng_0.0.tar.gz
14.11.2007 07:15
294.53k
BCU SDK packages
Filename
Last modified
Size
main/m/m68hc05-gnu/m68hc05-gdb_0.0.0-4_i386.deb
11.02.2007 22:18
2.18M
main/m/m68hc05-gnu/m68hc05-binutils_0.0.0-4_i386.deb
11.02.2007 22:18
3.8M
main/m/m68hc05-gnu/m68hc05-g++_0.0.0-4_i386.deb
11.02.2007 22:18
2.61M
main/m/m68hc05-gnu/m68hc05-gcc_0.0.0-4_i386.deb
11.02.2007 22:18
2.78M
main/m/m68hc05-gnu/m68hc05-runtime_0.0.0-4_all.deb
11.02.2007 22:18
5.1M
main/m/m68hc05-gnu/m68hc05-gnu_0.0.0-4.diff.gz
11.02.2007 22:18
9.05k
main/m/m68hc05-gnu/m68hc05-gnu_0.0.0.orig.tar.gz
11.02.2007 22:18
51.23M
main/m/m68hc05-gnu/m68hc05-gnu_0.0.0-4.dsc
11.02.2007 22:18
766
main/m/m68hc05-gnu/m68hc05-gdb_0.0.1_i386.deb
11.02.2007 22:42
2.19M
main/m/m68hc05-gnu/m68hc05-binutils_0.0.1_i386.deb
11.02.2007 22:42
3.87M
main/m/m68hc05-gnu/m68hc05-g++_0.0.1_i386.deb
11.02.2007 22:42
2.61M
main/m/m68hc05-gnu/m68hc05-gcc_0.0.1_i386.deb
11.02.2007 22:42
2.77M
main/m/m68hc05-gnu/m68hc05-dejagnu_0.0.1_all.deb
11.02.2007 22:42
8.4k
main/m/m68hc05-gnu/m68hc05-runtime_0.0.1_all.deb
11.02.2007 22:42
4.96M
main/m/m68hc05-gnu/m68hc05-gnu_0.0.1.tar.gz
11.02.2007 22:42
53.16M
main/m/m68hc05-gnu/m68hc05-gnu_0.0.1.dsc
11.02.2007 22:42
709
main/m/m68hc05-gnu/m68hc05-gdb_0.0.1_amd64.deb
06.03.2007 18:12
2.4M
main/m/m68hc05-gnu/m68hc05-binutils_0.0.1_amd64.deb
06.03.2007 18:12
4.14M
main/m/m68hc05-gnu/m68hc05-g++_0.0.1_amd64.deb
06.03.2007 18:12
2.67M
main/m/m68hc05-gnu/m68hc05-gcc_0.0.1_amd64.deb
06.03.2007 18:12
2.85M
main/m/m68hc05-gnu/m68hc05-gnu_0.0.0-4_source+i386+all.changes
16.02.2010 22:57
1.5k
main/m/m68hc05-gnu/m68hc05-gnu_0.0.1_amd64.changes
16.02.2010 22:57
1.15k
main/m/m68hc05-gnu/m68hc05-gnu_0.0.1_source+i386+all.changes
16.02.2010 22:57
1.56k
main/m/m68hc05-gnu/m68hc05-binutils_0.0.2_amd64.deb
11.08.2010 10:37
5.48M
main/m/m68hc05-gnu/m68hc05-binutils_0.0.2_i386.deb
11.08.2010 10:37
5.03M
main/m/m68hc05-gnu/m68hc05-dejagnu_0.0.2_all.deb
11.08.2010 10:37
9.16k
main/m/m68hc05-gnu/m68hc05-g++_0.0.2_amd64.deb
11.08.2010 10:37
2.74M
main/m/m68hc05-gnu/m68hc05-g++_0.0.2_i386.deb
11.08.2010 10:37
2.52M
main/m/m68hc05-gnu/m68hc05-gcc_0.0.2_amd64.deb
11.08.2010 10:37
2.9M
main/m/m68hc05-gnu/m68hc05-gcc_0.0.2_i386.deb
11.08.2010 10:37
2.7M
main/m/m68hc05-gnu/m68hc05-gdb_0.0.2_amd64.deb
11.08.2010 10:37
2.84M
main/m/m68hc05-gnu/m68hc05-gdb_0.0.2_i386.deb
11.08.2010 10:37
2.54M
main/m/m68hc05-gnu/m68hc05-gnu_0.0.2.dsc
11.08.2010 10:37
917
main/m/m68hc05-gnu/m68hc05-gnu_0.0.2.tar.gz
11.08.2010 10:37
67.32M
main/m/m68hc05-gnu/m68hc05-gnu_0.0.2_amd64.changes
11.08.2010 10:37
1.99k
main/m/m68hc05-gnu/m68hc05-gnu_0.0.2_source+all+i386.changes
11.08.2010 10:37
2.98k
main/m/m68hc05-gnu/m68hc05-runtime_0.0.2_all.deb
11.08.2010 10:37
6.42M
main/b/bcusdk/bcusdk-build_0.0.0-4_i386.deb
11.02.2007 22:32
355.54k
main/b/bcusdk/eibd-client-sources_0.0.0-4_i386.deb
11.02.2007 22:32
8.48k
main/b/bcusdk/libeibclient-dev_0.0.0-4_i386.deb
11.02.2007 22:32
11.08k
main/b/bcusdk/eibd-clients_0.0.0-4_i386.deb
11.02.2007 22:32
39.4k
main/b/bcusdk/eibd-server_0.0.0-4_i386.deb
11.02.2007 22:32
243.25k
main/b/bcusdk/bcusdk_0.0.0-4_all.deb
11.02.2007 22:32
3.6k
main/b/bcusdk/bcusdk_0.0.0-4.diff.gz
11.02.2007 22:32
211
main/b/bcusdk/bcusdk_0.0.0.orig.tar.gz
11.02.2007 22:32
433.03k
main/b/bcusdk/bcusdk_0.0.0-4.dsc
11.02.2007 22:32
730
main/b/bcusdk/bcusdk-build_0.0.1_i386.deb
11.02.2007 22:41
355.69k
main/b/bcusdk/eibd-client-sources_0.0.1_i386.deb
11.02.2007 22:41
9.1k
main/b/bcusdk/libeibclient-dev_0.0.1_i386.deb
11.02.2007 22:41
11.32k
main/b/bcusdk/eibd-clients_0.0.1_i386.deb
11.02.2007 22:41
46.89k
main/b/bcusdk/eibd-server_0.0.1_i386.deb
11.02.2007 22:41
314.81k
main/b/bcusdk/bcusdk_0.0.1_all.deb
11.02.2007 22:41
3.57k
main/b/bcusdk/bcusdk_0.0.1.tar.gz
11.02.2007 22:41
352.65k
main/b/bcusdk/bcusdk_0.0.1.dsc
11.02.2007 22:41
662
main/b/bcusdk/bcusdk-build_0.0.2_i386.deb
11.02.2007 22:42
475.37k
main/b/bcusdk/eibd-client-sources_0.0.2_i386.deb
11.02.2007 22:42
9.52k
main/b/bcusdk/libeibclient-dev_0.0.2_i386.deb
11.02.2007 22:42
14.35k
main/b/bcusdk/eibd-clients_0.0.2_i386.deb
11.02.2007 22:42
70.96k
main/b/bcusdk/eibd-server_0.0.2_i386.deb
11.02.2007 22:42
318.04k
main/b/bcusdk/bcusdk_0.0.2_all.deb
11.02.2007 22:42
3.63k
main/b/bcusdk/bcusdk_0.0.2.tar.gz
11.02.2007 22:42
455.94k
main/b/bcusdk/bcusdk_0.0.2.dsc
11.02.2007 22:42
425
main/b/bcusdk/bcusdk-build_0.0.2.1_i386.deb
11.02.2007 22:42
474.92k
main/b/bcusdk/eibd-client-sources_0.0.2.1_i386.deb
11.02.2007 22:42
9.57k
main/b/bcusdk/libeibclient-dev_0.0.2.1_i386.deb
11.02.2007 22:42
14.39k
main/b/bcusdk/eibd-clients_0.0.2.1_i386.deb
11.02.2007 22:42
70.36k
main/b/bcusdk/eibd-server_0.0.2.1_i386.deb
11.02.2007 22:42
320.96k
main/b/bcusdk/bcusdk_0.0.2.1_all.deb
11.02.2007 22:42
3.67k
main/b/bcusdk/bcusdk_0.0.2.1.tar.gz
11.02.2007 22:42
456.6k
main/b/bcusdk/bcusdk_0.0.2.1.dsc
11.02.2007 22:42
429
main/b/bcusdk/bcusdk-build_0.0.2.1_amd64.deb
06.03.2007 19:29
492.17k
main/b/bcusdk/eibd-client-sources_0.0.2.1_amd64.deb
06.03.2007 19:29
9.57k
main/b/bcusdk/libeibclient-dev_0.0.2.1_amd64.deb
06.03.2007 19:29
16k
main/b/bcusdk/eibd-clients_0.0.2.1_amd64.deb
06.03.2007 19:29
110.21k
main/b/bcusdk/eibd-server_0.0.2.1_amd64.deb
06.03.2007 19:29
342.45k
main/b/bcusdk/bcusdk-build_0.0.3_amd64.deb
18.11.2007 19:40
500.57k
main/b/bcusdk/libeibclient-dev_0.0.3_amd64.deb
18.11.2007 19:40
74.82k
main/b/bcusdk/eibd-clients_0.0.3_amd64.deb
18.11.2007 19:40
81.42k
main/b/bcusdk/eibd-server_0.0.3_amd64.deb
18.11.2007 19:40
347.44k
main/b/bcusdk/bcusdk-build_0.0.3_i386.deb
18.11.2007 19:40
484.73k
main/b/bcusdk/libeibclient-dev_0.0.3_i386.deb
18.11.2007 19:40
73.26k
main/b/bcusdk/eibd-clients_0.0.3_i386.deb
18.11.2007 19:40
62.59k
main/b/bcusdk/eibd-server_0.0.3_i386.deb
18.11.2007 19:40
326.86k
main/b/bcusdk/bcusdk_0.0.3_all.deb
18.11.2007 19:40
4.71k
main/b/bcusdk/eibd-client-sources_0.0.3_all.deb
18.11.2007 19:40
12.4k
main/b/bcusdk/bcusdk_0.0.3.tar.gz
18.11.2007 19:40
534.23k
main/b/bcusdk/bcusdk_0.0.3.dsc
18.11.2007 19:40
686
main/b/bcusdk/bcusdk-build_0.0.4_i386.deb
09.01.2009 22:15
441.81k
main/b/bcusdk/libeibclient-dev_0.0.4_i386.deb
09.01.2009 22:15
79.43k
main/b/bcusdk/eibd-clients_0.0.4_i386.deb
09.01.2009 22:15
79.15k
main/b/bcusdk/eibd-server_0.0.4_i386.deb
09.01.2009 22:15
259.28k
main/b/bcusdk/bcusdk_0.0.4_all.deb
09.01.2009 22:15
4.77k
main/b/bcusdk/eibd-client-sources_0.0.4_all.deb
09.01.2009 22:15
16.31k
main/b/bcusdk/bcusdk_0.0.4.tar.gz
09.01.2009 22:15
561.14k
main/b/bcusdk/bcusdk_0.0.4.dsc
09.01.2009 22:15
686
main/b/bcusdk/bcusdk-build_0.0.4_amd64.deb
09.01.2009 22:15
467.4k
main/b/bcusdk/libeibclient-dev_0.0.4_amd64.deb
09.01.2009 22:15
80.92k
main/b/bcusdk/eibd-clients_0.0.4_amd64.deb
09.01.2009 22:15
99.68k
main/b/bcusdk/eibd-server_0.0.4_amd64.deb
09.01.2009 22:15
299.15k
main/b/bcusdk/bcusdk_0.0.0-4_source+i386+all.changes
16.02.2010 22:57
1.57k
main/b/bcusdk/bcusdk_0.0.1_source+i386+all.changes
16.02.2010 22:57
1.49k
main/b/bcusdk/bcusdk_0.0.2.1_amd64.changes
16.02.2010 22:57
1.27k
main/b/bcusdk/bcusdk_0.0.2.1_source+i386+all.changes
16.02.2010 22:57
1.27k
main/b/bcusdk/bcusdk_0.0.2_source+i386+all.changes
16.02.2010 22:57
1.25k
main/b/bcusdk/bcusdk_0.0.3_amd64.changes
16.02.2010 22:57
1.11k
main/b/bcusdk/bcusdk_0.0.3_source+all+i386.changes
16.02.2010 22:57
1.49k
main/b/bcusdk/bcusdk_0.0.4_amd64.changes
16.02.2010 22:57
1.11k
main/b/bcusdk/bcusdk_0.0.4_source+all+i386.changes
16.02.2010 22:57
1.49k
main/b/bcusdk/bcusdk-build_0.0.5_amd64.deb
06.03.2011 18:06
395.89k
main/b/bcusdk/bcusdk-build_0.0.5_i386.deb
06.03.2011 18:06
363.39k
main/b/bcusdk/bcusdk_0.0.5.dsc
06.03.2011 18:06
1.01k
main/b/bcusdk/bcusdk_0.0.5.tar.gz
06.03.2011 18:06
891.94k
main/b/bcusdk/bcusdk_0.0.5_all.deb
06.03.2011 18:06
4.88k
main/b/bcusdk/bcusdk_0.0.5_amd64.changes
06.03.2011 18:06
2.25k
main/b/bcusdk/bcusdk_0.0.5_source+all+i386.changes
06.03.2011 18:06
3.19k
main/b/bcusdk/eibd-client-sources_0.0.5_all.deb
06.03.2011 18:06
16.9k
main/b/bcusdk/eibd-clients_0.0.5_amd64.deb
06.03.2011 18:06
70.61k
main/b/bcusdk/eibd-clients_0.0.5_i386.deb
06.03.2011 18:06
56.93k
main/b/bcusdk/eibd-server_0.0.5_amd64.deb
06.03.2011 18:06
346.52k
main/b/bcusdk/eibd-server_0.0.5_i386.deb
06.03.2011 18:06
293.9k
main/b/bcusdk/libeibclient-dev_0.0.5_amd64.deb
06.03.2011 18:06
105.63k
main/b/bcusdk/libeibclient-dev_0.0.5_i386.deb
06.03.2011 18:06
104.7k
main/b/bcusdk/libeibclient0_0.0.5_amd64.deb
06.03.2011 18:06
17.27k
main/b/bcusdk/libeibclient0_0.0.5_i386.deb
06.03.2011 18:06
16.97k
main/p/pthsem/pthsem_2.0.4-1_i386.deb
11.02.2007 22:38
59.32k
main/p/pthsem/pthsem-dev_2.0.4-1_i386.deb
11.02.2007 22:38
113.8k
main/p/pthsem/pthsem_2.0.4-1.diff.gz
11.02.2007 22:38
3.56k
main/p/pthsem/pthsem_2.0.4.orig.tar.gz
11.02.2007 22:38
645.07k
main/p/pthsem/pthsem_2.0.4-1.dsc
11.02.2007 22:38
578
main/p/pthsem/pthsem_2.0.5_i386.deb
11.02.2007 22:38
59.39k
main/p/pthsem/pthsem-dev_2.0.5_i386.deb
11.02.2007 22:38
114.55k
main/p/pthsem/pthsem_2.0.5.tar.gz
11.02.2007 22:38
640.52k
main/p/pthsem/pthsem_2.0.5.dsc
11.02.2007 22:38
509
main/p/pthsem/pthsem_2.0.7_i386.deb
11.02.2007 22:39
59.65k
main/p/pthsem/pthsem-dev_2.0.7_i386.deb
11.02.2007 22:39
114.81k
main/p/pthsem/pthsem_2.0.7.tar.gz
11.02.2007 22:39
647.14k
main/p/pthsem/pthsem_2.0.7.dsc
11.02.2007 22:39
272
main/p/pthsem/pthsem_2.0.7_amd64.deb
06.03.2007 18:12
62.84k
main/p/pthsem/pthsem-dev_2.0.7_amd64.deb
06.03.2007 18:12
121.48k
main/p/pthsem/libpthsem-compat_2.0.8_amd64.deb
16.02.2010 22:57
12.99k
main/p/pthsem/libpthsem-compat_2.0.8_i386.deb
16.02.2010 22:57
12.98k
main/p/pthsem/libpthsem-dbg_2.0.8_amd64.deb
16.02.2010 22:57
73.7k
main/p/pthsem/libpthsem-dbg_2.0.8_i386.deb
16.02.2010 22:57
71.05k
main/p/pthsem/libpthsem-dev_2.0.8_amd64.deb
16.02.2010 22:57
109.72k
main/p/pthsem/libpthsem-dev_2.0.8_i386.deb
16.02.2010 22:57
102.52k
main/p/pthsem/libpthsem20_2.0.8_amd64.deb
16.02.2010 22:57
47.5k
main/p/pthsem/libpthsem20_2.0.8_i386.deb
16.02.2010 22:57
43.21k
main/p/pthsem/pthsem_2.0.4-1_source+i386.changes
16.02.2010 22:57
1.07k
main/p/pthsem/pthsem_2.0.5_source+i386.changes
16.02.2010 22:57
1.03k
main/p/pthsem/pthsem_2.0.7_amd64.changes
16.02.2010 22:57
876
main/p/pthsem/pthsem_2.0.7_source+i386.changes
16.02.2010 22:57
781
main/p/pthsem/pthsem_2.0.8.dsc
16.02.2010 22:57
822
main/p/pthsem/pthsem_2.0.8.tar.gz
16.02.2010 22:57
671.44k
main/p/pthsem/pthsem_2.0.8_amd64.changes
16.02.2010 22:57
1.94k
main/p/pthsem/pthsem_2.0.8_source+i386.changes
16.02.2010 22:57
2.38k
精彩评论5
lwm178 发表于 2013-7-7 16:04:02 | 显示全部楼层
这个是什么神器呀
米香/fw南瓜 发表于 2013-7-7 18:58:46 | 显示全部楼层
好东西啊
米香/fw南瓜 发表于 2013-7-7 19:01:50 | 显示全部楼层
发个整包给我吧。。289628341@qq.com
lxn58 发表于 2014-7-11 09:57:11 | 显示全部楼层
这是什么东东呀,太高级了
GerMing 发表于 2014-12-17 14:08:12 | 显示全部楼层
这些是什么 用来干什么的
粉丝3238
帖子9937
